This discussion topic has been answered Discussion topic: Sky Q remote
Message posted on 11 Aug 2026 02:52 PM
My Sky Q remote won't turn my Panasonic tv on or off. Panasonic engineer said is a Sky fault. It used to work now it doesn't. Even with a new reprogrammed remote. I've restarted & reprogrammed both , but still nothing. It's annoying having to use 2 remotes just for turning the tv on & off. Especially it worked fine for years until recently.
Message posted on 11 Aug 2026 02:58 PM
@Sanmig+Queen wrote:My Sky Q remote won't turn my Panasonic tv on or off. Panasonic engineer said is a Sky fault. It used to work now it doesn't. Even with a new reprogrammed remote. I've restarted & reprogrammed both , but still nothing. It's annoying having to use 2 remotes just for turning the tv on & off. Especially it worked fine for years until recently.
What is the model number of your Panasonic TV? Many cheaper Panasonic models are actually made by Vestel so you could try pairing your remote to a Vestel code and see if it works.
Message posted on 11 Aug 2026 03:04 PM
Re: Sky Q remote
Panasonic TX-55, 2 years old. I'll try your suggestion thanks.
