Discussion topic: Sky Q remote
This message was authored by: SimonNevill
Sky Q remote
My Sky Q remote has stopped working
Re: Sky Q remote
Are you using it to control a Sky Glass TV or Sky Stream Puck?
Why did you stop using your Sky Stream remote?
Re: Sky Q remote
@SimonNevill
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well you’ll have a spare.
@Exiled-in-HH
Am I missing something? No mention of Glass or Stream, posted on Sky Q board and OPs first post.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Re: Sky Q remote
Possibly that the discussion started life elsewhere😉
Re: Sky Q remote
@Exiled-in-HH
Possibly, perhaps some housekeeping has found it on the wrong board. Correct advice provided anyway. Better late than never.
Re: Sky Q remote
Many that have issues with their Sky Stream remotes are advised to use a Sky Q remote😉
Re: Sky Q remote
@Exiled-in-HH
Almost certainly found when splitting Sky Glass issues and Stream issues into the new boards.
