21 Jul 2023 10:41 AM
I have a new Fire TV series 4 (not a firestick) and can't find a working remote control code so that I can turn volume up and down using my sky q remote... anyone know if this is possible?
29 Jul 2023 11:39 AM
Bingo! Had to go through a bunch of the JVC codes but eventually one worked.
24 Jul 2023 02:04 AM
I'm also having the same issue with my fire TV series 4 and would appreciate if anyone knows how to do it!
25 Jul 2023 07:36 PM
Just got the series 4 firetv. Had the same issue as others. Found through another forum that the series 2 tv's use JVC codes. Tried the first JVC code and BINGO, all working. Hope this help.
23 Aug 2023 03:16 PM
Thank you for this!
I just got the Fire TV 4 myself.
I went through the Sky setting/setup/remote and told it I was using a JVC TV and it got it first time (1 out of 25 options)
I use Amazon a lot so it seemed the wisest choice to use thier TV too and integrate with Alexa.
17 Dec 2023 12:36 PM
Thanks worked first time as suggested
17 Jul 2024 07:12 AM
Can someone psor the code used please
17 Jul 2024 07:54 AM
Hey
From memory, when going through the menus on the sky remote, the instructions on the TV just say it is "trying the 1st code, did this work?" I don't remember it giving me a code. I just followed the prompts on the screen.
Hope that helps
16 Aug 2024 12:21 PM
3075 worked for me
28 Nov 2024 08:56 PM
3075 worked for me two.
31 Jan 2025 07:00 PM
I've just bought a Panasonic TV-32S55AEY and JVC worked for me. Thank you.
