Discussion topic: Sky Q remote not working on apps.
Message posted on 05 Dec 2023 10:45 PM
My Sky Q remote works fine with the TV channels but has just stopped working on apps such as YouTube, Netflix etc. or on the Sky help. I have tried resetting pressing 7 and 9 together, then 1 and 3 but this does not enable me to use apps on the remote. How do I fix this?
Message posted on 06 Dec 2023 06:47 AM
Re: Sky Q remote not working on apps.
Hi @Ian+Robert Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Message posted on 06 Dec 2023 02:49 PM
Thanks for the advice but when I turned on Sky Q today the remote w
as working with the apps. Very mysterios so I can only assume that the overnight rest helped to get the remote working again.
Will try your solution if I have this problem again.
