Discussion topic: Issues with sky box loading tv schedule
This message was authored by: Customer16
Both my sky q and sky q mini box daily says "waiting for tv schedule", leading to us being unable to load channels or the tv guide. Additionally, all future planned recordings have been deleted. It also does not allow us to record, or live rewind any programme. The only way to fix this is to restart or reset the box, but this only last 24 hours, we have have to do it everyday.
why is this occurring, and can this be fixed?
thanks
Re: Issues with sky box loading tv schedule
thanks
Hi @Customer16
First make sure that all your Qboxes are onthe latest software.
Once this is done carry out a Reset Settings in the main Q box hidden menu.
Avatar for Customer16
Thanks for the response.
the boxes are up to date, and the resets work for just one day, then the issue arises again the next day.
This message was authored by: NeilA4
Made a complaint to Sky today about tv guide not loading & having to update the software at least once a week.
should have done it before now, but it used to be a 40 minute wait for an actual human being in tech support, so I've always left it.
However with an account issue to sort, I braved the wait & the upshot is I'm being sent a new Q box.
Hopefully quickly as well, because currently the tv is saying Waiting for TV schedule..........
Don't forget to take your viewing card out of the old box before handing it to the courier.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
