Discussion topic: Sky Q remote not fully working
This message was authored by: Noel+J
Have just bought new Samsung Qled TV have connected sky Q box which is working by using 2 remotes Samsung remote to turn on TV the Sky Q. Can change channels, pause etc but can not use volume control and not able to switch on and off. Sky box does not recognise TV when trying to reset.
Hope this makes sense
Re: Sky Q remote not fully working
Hi @Noel+J
First reboot the Q box.
Have you tried rebooting your Q box?
Then
Avatar for Noel+J
Thanks will try when I get home
Avatar for Noel+J
Hi Oldfella
Have tried your suggestions but still not working.
After going through the instructions on the TV to tune in the remote it is saying it does not recognise this TV.
could the TV be to new for my Sky Q box
@Noel+J wrote:
Hi Oldfella
Hi @Noel+J
You don't specify what brand TV you have.  Most of the TV brands are covered but there are still some obscure brands that have not been coded.
If your Television brand is not listed in the remote setup then have you tried Other brands category?
This message was authored by: Skull+Treaty
@oldfella wrote:
@Noel+J wrote:
Hi Oldfella
Hi @Noel+J
I think it's a Samsung from the original post
Yes @Skull+Treaty
should have revisited the earlier post again.
hi @Noel+J
There's little doubt that Samsung should be covered for all models.  It's not often that the TV manufacturers introduce a different code for newer models.
Sony codes here work on latest models and also the very early ones..
Main error in remote not pairing is that the remote is directly in line of the Q box during pairing.
ie
With the Q box on with green led try completly resetting your Bluetooth remote again.
Assume you have also tried the setup by Going to Home - Settings - Setup - Remote control.
Avatar for Noel+J
Yes, have tried everything you have mentioned.
I have typed in the TV model but it's not on the list.
This message was authored by: Makeitwork23
I have this issue too - did you get a conclusion?
Avatar for Noel+J
No
got in touch with Sky sent new remote but still not working
given up using 2 remotes
