Discussion topic: Sky Q quality issue
This message was authored by: Spacem4n20
Sky Q quality issue
Hey So long story short. My WiFi wasnt too strong so I was advised to go to SkyQ But the quality of the SkyQ compared to the SkyGlass is not good. Its blurry compared. I can still access Netflix and other apps via SkyGlass and you can see the difference between Why is my SkyQ quality so bad compared. It says its running in the highest quality, which is UHD but its definitely not Any tips or insight to why? Cheers
This message was authored by: DaveDrizen
Re: Sky Q quality issue
Are you talking about you main tv picture being blurry or just the apps. If it your main tv picture is nothing to with your broadband as unlike  Sky stream it get its signal from a dish outside your  property. If you have problems with your main tv picture you need to get in touch with Sky to send a engineer to check your dish and main box
