1
This discussion topic has been answered Discussion topic: Need a hub
This message was authored by: SkyQMiniBox
Need a hub
Engineer came out to fix sky a mini box last week. Still not working. We need to get this fixed as out tv with sky mini box is constantly not working ever since we have had the sky fibre out in.
Re: Need a hub
Hi @SkyQMiniBox
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue if you have the white Sky Max router then the mini needs to connect by WPS to your main Q box and not the Router.
Reboot the mini as above.
If the mini still does not connect  try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Re: Need a hub
Hi @SkyQMiniBox
To contact Sky
