Discussion topic: Sky Q not working
Message posted on 28 Dec 2023 06:48 PM
Sky Q not working
Hi my sky just has adverts for sky on loop over and over again and I can't select a channel or go to the home page. Checked remote, this works (volume etc), tried different hdmi portal. Nothing seems to work
Message posted on 29 Dec 2023 01:02 AM
Re: Sky Q not working
Snap x been down all night 😭 . Hopefully just the weather and will be working in the morning .
Message posted on 29 Dec 2023 08:01 AM
@Michelle70 wrote:Snap x been down all night 😭 . Hopefully just the weather and will be working in the morning .
If it was the weather you would see a "no satellite signal" error
Message posted on 29 Dec 2023 08:03 AM
@Matt108 wrote:Hi my sky just has adverts for sky on loop over and over again and I can't select a channel or go to the home page. Checked remote, this works (volume etc), tried different hdmi portal. Nothing seems to work
Volume control of the TV is via IR. Control of the box is via bluetooth. The first working is no guarantee the remote is still paired to the box (depending on what "etc" included). I would try to reconnect it by holding down 7&9.
