This discussion topic has been answered Discussion topic: Sky Q not received upstairs
Message posted on 21 Sep 2023 12:34 PM
Since having sky q box fitted I am unable to get any freeview or sky channels upstairs in the bedrooms, which I had when I had the HD box. Have tried re tuning to no avail just says no signal. Has anyone else experienced this problem.
Message posted on 21 Sep 2023 12:46 PM
Did you take out a Multiscreen subscription and order a Sky mini box for upstairs or are you just planning to watch what you can on Freeview?
A 'no signal' message normally comes from your TV.
Message posted on 21 Sep 2023 01:04 PM - last edited: 21 Sep 2023 01:05 PM
Re: Sky Q not received upstairs
hi @Gill24
The SKY Q boxes don't have any RF inputs / outputs that the SKY HD boxes had & engineers tend to just disconnect these from the old HD boxes rather than join them together.
Look at where your HD box and see if you can join the input from your Freeview Aerial to the Cable that routes to your upstairs TV
Message posted on 21 Sep 2023 01:23 PM - last edited: 21 Sep 2023 01:23 PM
Hi @Gill24
Looks like you may need a terrestrial Aerial amplifier so that you can connect multiple outputs from your aerial.
Something like this
Readily available from Internet sites.
You connect the TV Aerial to the input and then connect your local TV and the upstairs TV to the outputs.
Message posted on 21 Sep 2023 02:42 PM
No I do not have multiroom but with the old HD box my boys could watch the same sky channel as what I was watching downstairs.
Message posted on 21 Sep 2023 03:08 PM
Unfortunately you can't do that easily with SKY Q - to watch SKY channels you need the Multiscreen add on & a SKY mini box
See my earlier reply regarding Freeview
Message posted on 21 Sep 2023 03:40 PM
Message posted on 21 Sep 2023 04:25 PM
@Gill24 if you were willing to restrict the output of your Sky Q receiver to HD quality, then you could pass its HDMI output through a HDMI modulator in order to create a digital CODFM television signal for distribution to the upstairs bedroom televisions. A typical example of a suitable device would be the Triax HDMI to CODFM Modulator, but suitable quality modulators are not cheap.
Godfrey.
