Discussion topic: Voice command slow, sky go unreliable, forgets series links
Message posted on 21 Sep 2023 03:35 PM
Voice command slow
sky go unreliable
series link unreliable
Message posted on 21 Sep 2023 04:24 PM - last edited: 21 Sep 2023 04:28 PM
Re: Voice command slow, sky go unreliable, forgets series links
@Dimmer1 wrote:
Voice command slow
sky go unreliable
Hi @Dimmer1
First make a note of all Series links.
Then go into the Recordings - Scheduled section scroll right and remove the series link from each scheduled recording.
Once you are left with a list of Single recordings then delete each one until the scheduled section is completely empty.
Then carry out a Reset Settings in the Q box hidden menu.
Once the Q box is back up and running add back all your series links from the TVGuide.
Assume you are aware that you only set a series link for the very next showing. Future series links should be added automatically for subsequent showings when the previous one starts recording.
