Discussion topic: Sky Q not connecting to network
Message posted on 28 Dec 2025 08:35 PM
My TV was working fine and then suddenly lost connection to network. Can watch live TV but none of the apps. Tried everything, reset, switch on/off router, box and then everything but still nothing. Have Wi-Fi on all my devices so internet no problem. Don't know what else to do
Message posted on 28 Dec 2025 09:18 PM
Re: Sky Q not connecting to network
Hi @MJV3
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 28 Dec 2025 09:27 PM
Thank you will try it
