3
This discussion topic has been answered Discussion topic: Sky Q no HD
This message was authored by: Lucy47
Sky Q no HD
Evening. We've just had some work done at the house and both Sky Ariel's were removed. I can now only get a signal on non HD channels when just 1 port is used. I've tried both configurations (Ariel's/ports) with no success.
if both ports are in, in either config there is no signal.
any help would be appreciated
This message was authored by: nigea99 Answer
Re: Sky Q no HD
hi @Lucy47
It sounds like maybe one of the cables may be causing a short on the power.
Check that none of the fine very strands of the outer sheathing copeer are touching the central core wire.
BTW with SKY Q each cable carries approx half the channels - one is used for each polarity - one for horizontal & one for vertical
Re: Sky Q no HD
hi @Lucy47
Re: Sky Q no HD
Hi @Lucy47
Check that both cables do not have the central copper conductor bent or broken.
They should sit exactly in the centre of the connector and protrude by 2  or 3 mm
Avatar for Lucy47
Re: Sky Q no HD
Many thanks. I started again, cut cable, reconnected and now ok! The connectiors at the back are rubbish tho!
