Discussion topic: Sky Q multiroom
Message posted on 22 Jul 2025 08:21 AM
							Sky Q multiroom
I recently had to change my router. I have reconnected Sky Q on my main TV but I cannot get my multi room box in my kitchen to do anything. It will not connect and the remote will not let me connect to anything (and yes I have tried switching off everything, changed batteries in my remote). It's like there is no connection between the remote and the box.
Does anyone have any ideas?
Message posted on 22 Jul 2025 08:28 AM - last edited: 22 Jul 2025 08:29 AM
							Re: Sky Q multiroom
hi @Mona1972
Do you have a message on the mini regarding Accessibility ?
If so, this message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times. Once reset the remote must have line of sight of the mini until re-paired
Then try the 1&3 to re-pair & pair with the TV
If you don't have a message regarding accessibillity then may be you just need to reset & Repair the remote - see the later steps I mention above
