2
This discussion topic has been answered Discussion topic: Sky Q multi room box not working
This message was authored by: ShaunMatt
Multi room box stuck on same blue screen despite numerous resets.
stuck on accessibility screen and unable to choose ' settings' or 'skip for now' options that are shown.
Re: Sky Q multi room box not working
@ShaunMatt
Sky have suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
@ShaunMatt
Avatar for ShaunMatt
Many thanks- all sorted 👍
