Discussion topic: 'No signal detected' message
This message was authored by: MickBen
I have just replaced a damaged Sky HDMI cable with a brand new one, but when trying to activate my Sky Q box, I am just getting a 'No signal detected' message on screen. I have tried all the recommended troubleshooting measures more than once, but there is no change. The furthest I have progressed is to get the 'Hello' rebooting message on screen (which proves that the HDMI cable isn't faulty), but then it goes back to the original message. My equipment checker on the app indicates that everything should be working...so what else can I do?
Re: 'No signal detected' message
hi @MickBen
with the SKY Q box on, try pressing the following keys in sequence
Home 1 0 8 0 Home
Avatar for MickBen
Hi, Unfortunately, that doesn't seem to have worked. But thank you for the suggestion.
