Discussion topic: Sky Q mini
Message posted on 05 Jan 2024 10:00 PM
Sky Q mini
My sky Q mini box isn't working and I have reset it all and followed the steps to get it back on but it's still not working
The internet and main sky Q box are all working fine just the mini box
Message posted on 05 Jan 2024 10:07 PM
Re: Sky Q mini
Hi @Laura136
Reboot the mini as above.
