Discussion topic: Sky Q mini not working
This message was authored by: Samjarvis89
Error message saying check subscription entitles to view this channel on any channel or recording, worked fine on Saturday when all was installed and majority of sunday but now it's acting like I don't have multiroom.
Tried resetting the main and the mini to no avail, checked software updates, reconnecting router and reconnecting the mini to the main.
Not sure what else to try
Re: Sky Q mini not working
Hi @Samjarvis89
Try a Reset Settings in the main Q box hidden menu.
Then reboot the mini
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Avatar for Samjarvis89
Hi thanks for the response, unfortunately this hasn't changed anything still getting the same message.
Hi @Samjarvis89
Assume you have checked that all your Q boxes are on the same latest software?
Last two things I can suggest is first a Reset settings on the mini in its hidden menu similar to what you did on the main Q box.
Secondly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @oldfella just done reset on the mini and then the callback and neither have changed anything I'm afraid still getting the same message.
Hi @Samjarvis89
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent @Samjarvis89  an invite to chat.
Lisa - Sky Tech Team Expert
