15 Jan 2025 04:49 PM
Sky Q mini doesn't work. Does it need to be in range of main box?
15 Jan 2025 05:00 PM
@Isabel8 wrote:Sky Q mini doesn't work. Does it need to be in range of main box?
Yes.
15 Jan 2025 06:30 PM
Hi @Isabel8
Reboot the mini as above.
15 Jan 2025 11:57 PM
Many thanks for this. I think the problem is we have thick stone walls that cause signal problems. I use ethernet cable direct from router to TV. Mini box was for opposite wing of house that just about works through powerline system. Didn't realise the mini needed to talk to the main Q box. Think I will give up. Don't really need sky on the kitchen TV. Now want to try and get money back. It was hard sell when we gave up Sports and they downgraded Netflix to advert version without telling me. Bunch of chancers.
