Discussion topic: Sky Q mini doesnt work
This message was authored by: Isabel8
Sky Q mini doesn't work. Does it need to be in range of main box?
Re: Sky Q mini doesnt work
Yes.
Hi @Isabel8
Reboot the mini as above.
Avatar for Isabel8
Many thanks for this. I think the problem is we have thick stone walls that cause signal problems. I use ethernet cable direct from router to TV. Mini box was for opposite wing of house that just about works through powerline system. Didn't realise the mini needed to talk to the main Q box. Think I will give up. Don't really need sky on the kitchen TV. Now want to try and get money back. It was hard sell when we gave up Sports and they downgraded Netflix to advert version without telling me. Bunch of chancers.
