3
This discussion topic has been answered Discussion topic: Sky Q mini connection via mains
This message was authored by: MiBl
I have recently had to move my Sky Router  next to my SKY Q main box. A SKY Q Mini in another room has a bad wifi signal now.  I was told when SKY Q installed that it could also AUTOMATICALLY connect via the power lines if the signal was bad.  This doesnt appear to happen automatically.   I have seen a post that says you have to disable the the wifi  on the main SKY Q box, but the instructions didnt seem to work.  How can I set up the boxes so that they communicate via mains cables instead of Wifi?
This message was authored by: PandJ2020 Answer
Re: Sky Q mini connection via mains
@MiBl wrote:
An extender is my next port of call as i only changed it yesterday but am sure the original installer said it was possible to connect across the mains and some posts seem to suggest this.
Not without additional hardware.
Not true.  (There is a back story about this - but was not implemented)
Sky can supply extenders - I presume they haven't sent you those...?
Avatar for MiBl
Answered - Go to Answer
