Discussion topic: Sky Q mini boxes
Message posted on 15 Mar 2024 10:34 AM
Sky Q mini boxes
A month ago I cancelled tnt with bt and arranged to have it through sky. This happened on 19/02/24 since then our two sky Q mini boxes have stopped working saying check your subscription. Although sky comes up no channel will work.
I'm up to date with payments, and I've tried all the things I've found online to get it working but it won't on either box. My account still says they're active and paid for but we have no channels working.
I would be grateful if you could find away to switch them back on. Thank you.
kindest regards
Mrs Rosemary Savile
Message posted on 15 Mar 2024 10:51 AM
Re: Sky Q mini boxes
@RSav1
We can't switch anything back on. I’m afraid you aren’t contacting Sky Customer Services on here. This is a customer to customer forum where we try to help each other. Also your post has been moved from the Email board as that's for issues with Sky email. It's not an email route to Sky.
Message posted on 15 Mar 2024 10:54 AM - last edited: 15 Mar 2024 10:56 AM
kindest regards
Mrs Rosemary Savile
Hi @RSav1
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Failing this
Try a Reset Settings in the main Q box hidden menu.
