Discussion topic: Q box problem
Message posted on 15 Mar 2024 09:40 AM
Q box problem
My sky Q box is making a buzzing sound and I m getting a message
There is no signal or the signal is not strong enough. Please check the connection source. I have checked everything. However the multi box is working perfectly well in the other room. I think the Q box is broken.
Message posted on 15 Mar 2024 10:51 AM
Re: Q box problem
hi @AnnNicholls
Assume you have carefully checked the the HDMI cable between the Q box and TV is correctly located at both ends?
Also have you rebooted the main Q box?
