6
This discussion topic has been answered Discussion topic: Sky Q mini box
This message was authored by: Scott189
Sky Q mini box
Sky Q mini box not working there's a message on top of my screen saying.
Please check your subscription entitles you to view this channel on this box. Otherwise if you're using this box for the first time please wait a few minutes.
its been like this for 2 hours any help would be appreciated thanks
Re: Sky Q mini box
@Scott189
Are you perhaps trying to watch something in UHD (not possible on a mini box) or in HD without the HD add on?
Re: Sky Q mini box
@Scott189
Re: Sky Q mini box
Try a power cycle of the mini box first.
If that doesn't work you may need to power cycle the main box as well.
Avatar for Scott189
Re: Sky Q mini box
No I'm not trying to watch anything in uhd none of the channels are working
Avatar for Scott189
Re: Sky Q mini box
I've done that but still the same
Re: Sky Q mini box
@Scott189
Try a reboot of your broadband, then do a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: Gary294
Re: Sky Q mini box
Can't connect mini box think box has packed up
