This discussion topic has been answered Discussion topic: Sky Q mini box
Message posted on 27 Jun 2025 05:36 PM
Sky Q mini box not working there's a message on top of my screen saying.
Please check your subscription entitles you to view this channel on this box. Otherwise if you're using this box for the first time please wait a few minutes.
its been like this for 2 hours any help would be appreciated thanks
Message posted on 27 Jun 2025 05:37 PM
Are you perhaps trying to watch something in UHD (not possible on a mini box) or in HD without the HD add on?
Message posted on 27 Jun 2025 05:39 PM
Re: Sky Q mini box
Try a power cycle of the mini box first.
If that doesn't work you may need to power cycle the main box as well.
Message posted on 27 Jun 2025 05:43 PM
Re: Sky Q mini box
No I'm not trying to watch anything in uhd none of the channels are working
Message posted on 27 Jun 2025 05:49 PM
Re: Sky Q mini box
I've done that but still the same
Message posted on 27 Jun 2025 06:29 PM
Re: Sky Q mini box
Try a reboot of your broadband, then do a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 01 Aug 2025 07:38 PM
Re: Sky Q mini box
Can't connect mini box think box has packed up
