Discussion topic: Sky Q mini box
Message posted on 29 Apr 2024 08:19 PM
Sky Q mini box
My mini box disconnects from the network ever day. I have to reset the connection to the router and the main box. I'm using trooli on 2.4 setting. It has been ok for about 8 months but now I'm not able to watch anything in bed in the morning without getting up and messing around for half hour. Nightmares!!!
Message posted on 29 Apr 2024 08:25 PM
Re: Sky Q mini box
Hi @melanie78
On 3rd party broadband your Mini if using WiFi can only connect yo your main Q box (and not your Router).
Reboot the mini as above.
Message posted on 29 Apr 2024 08:33 PM
Re: Sky Q mini box
Thanks for that info, I do this everyday to get back up and running however, it has been ok for some time now. From what I read , see that sky is an all or nothing package that offers little freedom to use other broadband providers. If this the case do I have a dilemma? Get rid of sky or get rid of my broadband provider, what would you do? By getting a sky Q booster, I'm again paying to make a system work that worked perfectly before. The issue was that the broadband was unreliable and expensive. Let me know your thoughts please? Thanks
Message posted on 29 Apr 2024 08:52 PM
Re: Sky Q mini box
Hi @melanie78
Sky are obliged to issue Sky Q WiFi boosters free of change to aid Sky Q connectivity.
There would literally be millions of Q users on non Sky broadband
