Discussion topic: Sky Q mini box
This message was authored by: HENDO1872
Sky Q mini box
Are you able to connect sky q mini box using only 2.5GHz wireless ? I am trying to solve a problem where the sky boxes  are interfering with my PS5 which is set to 5GHz only. When I switch off 5GHz on the main box the mini box no longer connects is there a way around this ?
Re: Sky Q mini box
Hi @HENDO1872
Mini boxes if on WiFi use the 5Ghz band to connect to the main Q box.
Don't suppose you have the option to connect the mini by Ethernet to your Q box.
Avatar for HENDO1872
Re: Sky Q mini box
no ethernet is not an option unfortunately
