Discussion topic: Sky Q mini box
This message was authored by: Pamelarothery
Sky Q mini box
My sky mini box won't connect.
Re: Sky Q mini box
Hi @Pamelarothery
Reboot the mini as above.
Avatar for Pamelarothery
Re: Sky Q mini box
Thank you.  I've tried that.  Mini box won't go past stage 2 ??   This has been going on for weeks
Re: Sky Q mini box
Hi @Pamelarothery
Reset your remote to infrared mode by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
Don't try further pairing at this stage.  In infrared mode it will work any Q box but it must have line of of sight and must be pointed directly at the mini.
Then reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the Q box (Amber led).
Then see if you can get past Step 2 with the remote in infrared.
If you can get the mini working then you can pair the remote again to the mini.
Re: Sky Q mini box
The mini box remote or main box?
Re: Sky Q mini box
The mini remote @Pamelarothery
