Discussion topic: Q main box has red light every night
This message was authored by: Russ+Elliott
Evry night the main Q bix has a ref lught on the front and when truned on it appears to go through a reboot procedure. Not a real problem
ither than any mini box in other tooms cannot be used jntil the main box has gone through this reset set up. Is this normal ot is there some
sort of fault with the main box.
Re: Q main box has red light every night
@Russ+Elliott
It's possibly the Standby settings are on the default eco mode as per this link
https://www.sky.com/help/articles/using-the-standby-settings
If you use Sky overnight try changing the setting to None or Active.
