Discussion topic: Sky Q mini box will not connect
Message posted on 05 Oct 2023 03:00 PM
The Home Screen is showing on tv but no channels connecting. We have 1 sky Q box working but the other one has stopped working.
Message posted on 05 Oct 2023 07:11 PM
Re: Sky Q mini box will not connect
Hi @GaryAnne
Reboot the mini as above.
Message posted on 13 Aug 2024 10:52 AM
H I have tried this multiple times with no success. This was working before so not sure if I needs booster?
