5
This discussion topic has been answered Discussion topic: Sky Q mini box uhd not compatible
This message was authored by: SteveS2
Purchased new uhd tv only to find out sky Q mini box is not compatible with uhd
This message was authored by: PandJ2020 Answer
Re: Sky Q mini box uhd not compatible
@SteveS2 wrote:
Thanks I realise that but then you have to sign in to each app again pain!
Sure, but only once...
@SteveS2
Sorry that you did not realise this..
It is not really a secret and anyone visiting these groups will find we try to point this out regularly.
SKY mini boxes have not changed since their introduction when UHD was really in it's infancy & the hardware just doesn;t support it
If you really want to get SKY in UHD on your new TV you would need  consider switching to SKY Stream  but it is a different product and relies on good internet connection
Avatar for SteveS2
Thanks I now have good broadband connection having had to switch from sky to get fibre broadband
As noted, the mini cannot output UHD.  (Nor, annoyingly, downscale material to play in HD)
However, depending on the material you want to watch you may be able to use the TV's in-built apps for UHD, e.g. NetFlix.
Avatar for SteveS2
