4
This discussion topic has been answered Discussion topic: Sky Q mini box scrolling
This message was authored by: Durvol
When I access the Home Screen on my sky mini box it immediately starts scrolling to the right on top picks until it reaches the last selection. If I move down to the next line it does the same thing and you cannot go back to the left. I thought it may have been a stuck button in the remote, but I have paired my main SKy Q remote with the box and it does the same thing. Any suggestions?
Avatar for Durvol
This message was authored by: Durvol Answer
Re: Sky Q mini box scrolling
Hi yes I had tried a reset and didn't think it had worked, but after leaving it switched off for an hour and then turning it on, it now appears to be working as normal. Thanks
Have you tried a reboot?
Avatar for Durvol
Yes rebooted both boxes and did software update.
Hi @Durvol
If you haven't already
Try a Reset Settings in the mini box hidden menu.
Carry out the first Reset (Reset Settings).
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
Avatar for Durvol
Answered - Go to Answer
