Discussion topic: Sky Q mini box, remote not resetting
Message posted on 07 Apr 2024 04:04 PM
Hi. Remote stopped working so I changed the batteries. On putting new batteries in the red LED lit up for a few seconds but still didn't control the box. (the LED lights up if i remove and reinsert the batteries).
I have subsequently tried holding 7&9 but this has no effect on the box and the LED does not flash on the remote. I have also reset the box and cleaned the battery connections on the remote.
Any advice other than 'buy a new remote'?
Message posted on 08 Apr 2024 12:56 AM
Re: Sky Q mini box, remote not resetting
Please try the below and see how you get on
Simultaneously press and hold buttons 7 and 9 until the LED flashes four times. Ensure you're pointing the remote at the Q box, then press buttons 1 and 3 together. Hold them until the remote LED flashes twice. Follow the on-screen instructions to re-pair the remote to the Q box
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 08 Apr 2024 09:35 AM
Thanks, but as I said, the light doesn't flash when I hold 7&9. Absolutely no response at all.
Message posted on 08 Apr 2024 04:29 PM
@Tommacdonald1 when you say you reset the box did you boot your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 03 May 2024 02:07 PM
I'm in the same predicament and have reset the mini box but cannot get any response from the remote 🤷🏼♀️
Message posted on 03 May 2024 05:43 PM
Try 4+6 then 1+3
Message posted on 03 May 2024 06:26 PM - last edited: 03 May 2024 06:27 PM
If the remote Led is not flashing when you press and hold 7 & 9 then it is faulty.
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
