Discussion topic: Our sky box has locked up
Message posted on 03 May 2024 05:47 PM
Message posted on 03 May 2024 05:56 PM
Re: Our sky box has locked up
Hi @Aronpriest What happens when you switch it off at the mains, wait 30 seconds then switch it back on.
Message posted on 03 May 2024 05:58 PM
It comes back locked same guide picture and we can't control it
Message posted on 03 May 2024 06:21 PM
Hi @Aronpriest
First check on you remote that none on the buttons are stuck. Don't forget the Sky Logo button.
Then
