Discussion topic: Sky Q mini box fault
Message posted on 31 Jan 2024 01:15 PM
I have tried new batteries and the control from my main box. Still won't respond. I have also used the mini remote control on my main box downstairs and it works
The volume control on the remote control still works. So there is nothing wrong with the remote.
I believe the sky Q mini has failed
Message posted on 31 Jan 2024 05:56 PM
Re: Sky Q mini box fault
The volume control on the remote control still works. So there is nothing wrong with the remote.I believe the sky Q mini has failed
@MartynFisher Have you tried rebooting your mini Q box ie
then re-pairing the remote
Message posted on 31 Jan 2024 06:09 PM
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
