Discussion topic: My sky is not working
This message was authored by: Sarahlou82
It is saying there is a connectivity problem
Re: My sky is not working
Hi @Sarahlou82
Assume this your main Q box?
Try a Network Reset found in main Q box Home - Settings - Setup - Network.
If it is a mini
Reboot the mini as above.
