Discussion topic: Sky Q mini box constantly losing connection
Message posted on 21 Apr 2024 01:08 PM
My SkyQ mini box has started losing connectivity every few seconds. I have read all the similar messages and reset everything possible from router, mini box and main Sky Q box several times. I have also cleared my HD so that is only at 18%. What can I do next?
Message posted on 21 Apr 2024 01:34 PM
Re: Sky Q mini box constantly losing connection
Hi @Kacey4141
Have you carried out a Network reset on the mini?
