Discussion topic: Multi room not working
This message was authored by: CNS1
Multi room has stopped working
we can only get on to apps through the tv . No response from sky. Screen shows check source.
have tried switching off at the plugs but didn't change anything
Re: Multi room not working
Hi @CNS1
Reboot the mini as above.
