2
This discussion topic has been answered Discussion topic: Multi room
This message was authored by: Mkean2014
Multi room
I have multi room and 1 sky q mini. If I order another mini box is that an extra multi room charge each month?
Matthew Kean
This message was authored by: nigea99 Answer
Re: Multi room
hi @Mkean2014
No,  the multiscreen subscription covers all mini boxes, so there is only the initial admin fee
Re: Multi room
hi @Mkean2014
Re: Multi room
BTW @Mkean2014
You may already know but just in case you don't - you can  use a maximum of 2 minis at the same time for SKY content - Satellite/Recordings-  (only one if you have the non UHD box - Hardware version 32Cxxx) although you can have up to 4  on the account
You may be able to use more at the same time if the first ones in use are only being used for Streaming apps such as Netflix or Disney+
