Discussion topic: Sky Q mini box connectivity
Message posted on 26 Jan 2024 05:07 PM
We have Sky Q and a couple of mini boxes, but the TV in the kitchen is constantly freezing the picture to the point where it is just not viewable, the others are upstairs and they work OK. Any thoughts? Thanks
Message posted on 26 Jan 2024 05:10 PM
Re: Sky Q mini box connectivity
@HSO27 Have you tried rebooting your main Q box ie
then reboot the mini box
the kitchen may also be problematic with all the electrical equipment that is in there disrupting the signal
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 26 Jan 2024 05:16 PM
Hi @HSO27
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the minis.
Start with the one nearest to the main Q box or if on Sky broadband the one nearest to the Sky router if nearer than the main Q box.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. When you carry out the network reset on the second mini use the nearest Q device for WPS (Main box, Sky router or first connected mini)
Message posted on 26 Jan 2024 05:17 PM
Thanks worth checking out
Message posted on 28 Jan 2024 09:25 AM
My thanks for all the advice and guidance you have provided,as one of you kindly suggested I contacted Sky on Friday evening. They sent an engineer round Saturday afternoon, he rebuilt the entire mesh network we have, re configured a few things and installed a booster. Since them all working well - fingers crossed.
Thanks again
