Discussion topic: Sky Q mini Resolution
Message posted on 09 Jun 2023 11:57 AM
Hi,
I am considering upgrading to Sky Q with multiscreen, but cannot find a definitive answer on the max resolution from the SkyQ mini boxes. Some forums suggest it is limited to 720i, which would actually be a downgrade from my current Sky+HD mutiroom setup.
Please can you confirm what the output resoution is for Sky Q minis (when paired with an UDH Sky Q main box).
Also, are there any plans in the near future to support 4k UHD from the minis?
Thanks.
Message posted on 09 Jun 2023 12:03 PM - last edited: 09 Jun 2023 12:08 PM
Re: Sky Q mini Resolution
1080i or 1080p selectable in a menu. Mini boxes can also output 720p or even 576p
https://www.sky.com/help/articles/changing-the-screen-resolution-setting
No: they don't have HDMI 2.0 / HDCP 2.2 (and current main Q box hardware could not support UHD Mini boxes)
Message posted on 09 Jun 2023 12:04 PM - last edited: 09 Jun 2023 12:05 PM
@D.Harrison wrote:
Hi,
Thanks.
hi @D.Harrison
SKy Minis native resolution is 1080i although it can be set to 1080p
There are no known plans to introduce 4K minis - existing minis don't have the hardware & with the introduction of SKY Stream are not likely to have new upgrades
Message posted on 09 Jun 2023 12:09 PM
Will sky stream provide a solution to support 4k in multiple rooms then?
Is it worth me looking at that now rather thanSky Q (does it currently offer access to all the same content)?
Message posted on 09 Jun 2023 12:53 PM - last edited: 09 Jun 2023 12:55 PM
All Glass & Stream products support 4k, however you can only have one or the other you won't be able to mix Q with Stream/Glass.
Some channel may not be available on Glass and there are no +1 variants Glass channel lists here https://www.sky.com/help/articles/tv-channel-list-sky-glass
Message posted on 09 Jun 2023 12:56 PM
@D.Harrison wrote:Will sky stream provide a solution to support 4k in multiple rooms then?
@D.HarrisonYes BUT do your research as it is very very different from either +HD or Q, it also does not have as many channels.
Message posted on 09 Jun 2023 01:05 PM - last edited: 09 Jun 2023 01:16 PM
Yes, but each UHD datastream is going to eat something like 25mbs of internet bandwidth, so 'average' Superfast FTTC can't be relied on to support more than two concurrent outputs at that resolution. Realistically multiple Stream pucks running in UHD within a subscription address necessitates Ultrafast broadband, preferably FTTP.
