Discussion topic: My mini box upstairs won’t work since I had full fibre broadband fitted last week
This message was authored by: Chris+R92
The Sky  mini box upstairs can't connect to the new full fibre broadband we had last week.
We've followed the instructions on screen, but it still can't connect
Re: My mini box upstairs won’t work since I had full fibre broadband fitted last week
Hi @Chris+R92
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
This message was authored by: Invisiblename
The mini box doesn't connect to your broadband, it connects to WiFi network from the Sky Q main box.  Following the suggestions from @oldfella  should resolve your connection issue.
I am just another Sky customer!
