Discussion topic: Sky Q main box
Message posted on 03 Jan 2026 09:49 AM
Sky Q main box
The sky main box will not switch on
Message posted on 03 Jan 2026 10:01 AM
Re: Sky Q main box
Hi @Ble1 Have you tried the power button on the box itself? To rule out a problem with the remote.
Message posted on 03 Jan 2026 10:05 AM
Re: Sky Q main box
Can someone call me be easier to explain
It's not the man box one of me small boxes
Message posted on 03 Jan 2026 10:14 AM
Re: Sky Q main box
Have tried a reboot turn the box off at the mains leave for couple of minutes then switch back on, and let the box do it startup procedure.leave for couple of minutes after your tv screen goes blank after reboot, then try taking the box out of stand by I had a similar problem when I tried turning my box on first thing one mornings little while ago and this and this cured the problem
Message posted on 03 Jan 2026 10:15 AM
Re: Sky Q main box
Yes I have tried all help lines that Sky has said to do
Message posted on 03 Jan 2026 10:16 AM
Re: Sky Q main box
It was my mini box the mini box the same as you
Message posted on 03 Jan 2026 10:22 AM
Re: Sky Q main box
What colour is the light on the front of the box ? Amber or red?
Message posted on 03 Jan 2026 10:51 AM
Re: Sky Q main box
Red, blue rotating Q
Message posted on 03 Jan 2026 10:52 AM
Re: Sky Q main box
Box will not turn on, can't get into settings
Message posted on 03 Jan 2026 10:54 AM
Re: Sky Q main box
Yes, unplugged everything, lots of times
Message posted on 03 Jan 2026 11:06 AM - last edited: 03 Jan 2026 11:07 AM
Re: Sky Q main box
Message posted on 03 Jan 2026 11:47 AM
Re: Sky Q main box
In that case you need to contact Sky sounds like your box has gone faulty and Sky need to replace it
Message posted on 03 Jan 2026 11:50 AM
Re: Sky Q main box
Hi @Ble1
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 03 Jan 2026 05:21 PM
Re: Sky Q main box
@MightyQuinn wrote:
@Lee330 wrote:Can someone call me be easier to explain
Hi @Lee330 As we are fellow customers, nobody is going to call you. It is a bit confusing, why is @Holly139 answering the questions put to you?
And who is @Ble1 who started the thread in the first place?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
