Discussion topic: Replacements Sky Q box voice command not working
This message was authored by: JS75
Sky engineer visited on 1st December and replaced my main SkyQ box. Since then I cannot use the blue botton on my remote to use voice commands and search for TV choices. Please fix
Re: Replacements Sky Q box voice command not working
hi @JS75
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
