3
This discussion topic has been answered Discussion topic: Sky Q issue after moving to Virgin broadband
This message was authored by: elljay18
I have just moved my broadband from Sky to Virgin but keeping my Sky Q.  Sky have said they'll want my equipment back which is fair enough but it includes a broadband booster which was installed to help my mini box get a connection.
When I unplug the booster I am unable to view  TV on my mini box.  Unfortunately my main living room TV is connected to the mini box with the main Sky Q box being in the bedroom.
Has anyone else had this issue?  Will Sky allow me to keep the broadband booster if I explain my Sky Q won't function properly without it?  I believe there is also a Sky Q booster available - how would I request one of these?
This message was authored by: Addie15 Answer
Re: Sky Q issue after moving to Virgin broadband
Hi there! Thank you for escalating this. We have sent an invite to @elljay18.
hi @elljay18
I have escalated your post to a SKY support team, who, hopefully, will be in touch to let you know if th ebooster does indeed need to be returned or whether you can keep it & your account be updated or whether there are other options
Please see this link re the escalation and what you might see:
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Avatar for elljay18
I chatted via message and now don't have to return the booster - very easy to do via the forum - thank you!
