Discussion topic: Sky Q isn’t working
Message posted on 29 May 2024 07:45 PM
Sky Q isn’t working
Sky Q isn't working
Message posted on 29 May 2024 07:47 PM
Re: Sky Q isn’t working
Not a lot for us to go on. More information please… Any error messages for a start?
Message posted on 29 May 2024 08:06 PM
Same here. Screen froze about 20 minutes ago and it came up saying technical fault, channel not found, on all channels.
Message posted on 29 May 2024 08:10 PM
Same with mine technical fault channel not found
Message posted on 29 May 2024 08:16 PM - last edited: 29 May 2024 08:27 PM
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Alternatively try a reboot of your sky Q then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 29 May 2024 08:24 PM
Restart of the box has worked here for the minute.
Message posted on 29 May 2024 09:02 PM
Mine has gone too, was working fine but no satellite signal about 2030. Tried to restart etc but nothing.
Message posted on 29 May 2024 09:09 PM
mine is completely the same
Message posted on 29 May 2024 10:41 PM
I've tried this and my sky box keeps repeating the initial startup. I can't even get to the Home Screen to check the connection. Before I rebooted the sky box my satellite connection had an x, so the satellite feed isn't coming through. Any other ideas??
Message posted on 29 May 2024 10:46 PM
No error message, just repeats the sky startup after powering up after unplugging it for 30 sec. The skybox has has also stopped responding to the remote, but the remote works on every thing else
