Discussion topic: Sky Q is unreliable
Message posted on 21 Jun 2024 06:58 PM
Sky Q is unreliable
We have sky q and it keeps stopping working. At the moment mini box is not working even though we have turned main box off and on
Message posted on 21 Jun 2024 07:02 PM
Re: Sky Q is unreliable
@Mollymoo77
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 21 Jun 2024 07:54 PM
Hi @Mollymoo77
Try reconnecting both Boxes.
When the main Q box is connected and reboot it again and then when this is completely back up sand running reboot the mini.
Reboot the mini as above.
Message posted on 23 Jun 2024 05:02 AM
Thanks for the reply....
we had tried this already with sky over the phone. Sky said that both my mini boxes stay on yellow light so require changing so sky are posting me out 2x new ones in the post. This is not the first time we have had issues and seems ridiculous that both boxes require renewing as they are under a year old!
