1
This discussion topic has been answered Discussion topic: Sky Q hardwired issues
This message was authored by: Michaelsk
Hi There,
My sky Q box has been hardwired, via TP link Powerline plugs for the last 4 years quite happily.
I don't have a Sky router, I use Ubiquiti Dream Machine, and as we all know Sky H/W is not happy connecting to none sky routers for its own mesh. If I try an connect via WiFi it will stay connected for about 2 mins.
So for the last 4 years my Sky Q and SkyQ mini have all being playing nicely and connecting to my router hardwired via the TP link Powerline plugs. Until yesterday! Now I just get the 'No IP obtained' Error message.
So far I have
  1. Rebooted the router at least 3 times
  2. turned off the Sky Q at least 3 time
  3. Gone into the engineer menu '001' and disabled the Wifi twice, It seems to turn itself on again
  4. renabdled Wifi in a vain attempt to get that working, worked for 2 mins
  5. disabled Wifi
  6. tried reconnecting via wired, it failed to obtain an IP
Any other suggestions ? I'm slightly baffeled
Michael
Avatar for Michaelsk
Level 2 icon
This message was authored by: Michaelsk Answer
Re: Sky Q hardwired issues
After much trouble shooting, it turned out that two off my four tplink devices died at the same time!
 Replacement devices now installed, everything working as normal
Level 2 icon
