Discussion topic: Sky Q hard drive
Message posted on 09 Feb 2024 10:52 PM
Sky Q hard drive
My Sky Q hard drive has an error for the second time and is not able to retrieve recordings. Last time this happened it was a hard drive reset which wiped everything recorded and I suspect will be the case again.
thing is, wiping it gives me no faith in recording things and having it happen a third time when the hard drive is obviously now a problem.
can I get a replacement Sky Q box and restore a little faith?
Message posted on 09 Feb 2024 10:55 PM
Re: Sky Q hard drive
thing is, wiping it gives me no faith in recording things and having it happen a third time when the hard drive is obviously now a problem.can I get a replacement Sky Q box and restore a little faith?
@Claire974 yes if you follow the link below there is an option to order a new Sky Q box it about halfway down the page
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Feb 2024 05:27 AM
If Sky arrange a doorstep box swap rather than sending an engineer remember to remove your viewing card from the faulty box before it disappears into the back of a DPD van.
Message posted on 10 Feb 2024 05:45 AM - last edited: 10 Feb 2024 05:45 AM
And check the new box uses the same type of power connector (if you don't take that out of the box and try to use the existing one)
