Discussion topic: Sky Q freezing
This message was authored by: MoaT
Sky Q freezing
I have a single main Sky Q box (so no additional mini boxes) and I also get my broadband from Sky but I'm unable to watch live TV for longer than 20-30 minutes before the picture freezes but the sound continues. If I try to change channel or turn the box off I just get a plain blue screen and have to turn everything off at the wall for a few minutes to reset it. This problem only happens with live TV, anything downloaded or recorded is absolutely fine.
Re: Sky Q freezing
Hi @MoaT
Have you worked through the official troubleshooting steps here?
https://www.sky.com/help/articles/sky-box-problems/
If you do and it still doesn't work or remain stable, you will have the option to contact Sky and get an engineer or replacement box.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
